looking for service manual info for a 2006 verado fuel pump module
2004 searay
i have a verado 225hp, serial# 1b546019. the unit runs for about 5 minutes then dies. fuel pressure drops to nothing. i just need a decription of how the module works with the internal float.
i have a later manual but it states there is no internal float inside this module so i am assuming they realized there was an issue with the design and changed it out.
Texasmark
Wish you luck. If its not in the service manual, don't expect any luck. A lot of components of different things are private to keep the competition from copying. External dimensions and performance specs don't tell the contents or design criteria so they aren't usually a problem. I found that to be a problem with farm machinery when you can't find a replacement part (assembly) and have to try to fix what you have. Service manuals are primarily how that component functions with other related system components.
Fun Times
Search BULLETIN - FUEL SUPPLY MODULE (FSM) TROUBLESHOOTING 22-MAY-2009
Plus scroll down past your parts catalog for other possibilities of like information,
ejnichol
Heres a video walk through of the Mercury FSM that might be helpful. Just rebuilt a VP pump assembly and similarities in design was interesting.
<iframe width="560" height="315" src="
" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Texasmark
Glad you have some help. Must be a large enough problem Mercury wide to warrant this attention.....I would think.
