Re: looking for speed
Studly, thanks for the vote of knowledge...the "Real" prop guru, professor Dhadley is around here somewhere, and when he speaks, listen...pick his brain when ya get the chance.<br />As for the Laser II, is it in like-new condition??? If I had the choice, I'd opt for a higher tech prop that will stay hooked at that heigth. I realize you may not want to go through that type of purchase as well..<br />It sounds a bit strange to be in only the 2nd hole down and be 2-1/2" above bottom with AV plate...does this boat have a stepped transom??? a cut-out at the bottom with your thru-hull fittings???
