looking for the name of a connector, Force 120hp 1996
zymox
Hi,
I'm looking for the name of the 4-pin connector that connects to the ignitioncoil on a Force 120hp. See picture....
I've found the harness new but almost 100$ plus custom and freight is ridiculous pricey for what it is...
pnwboat
It looks like an Amphenol Superseal 1.5 series connector. There are thousands of variations of this connector (round pin, square pin, male, female, pin spacing etc, etc), so you need the actual part number.
Since the ignition system on your motor uses a Mercury ignition coil, look at the used Mercury outboard ignition coil harnesses on the auction sites. You'll see they are much more reasonably priced.
zymox
pnwboat, Thank you for the info, much appreciated. I actually have a hole bunch of those connectors but they just doesn't really look the same so I assumed that it had to be some other kind. I couldn't find anything that looks 100% on the net either. I'll try to see if there is a partnumber stamped on the connectors. They are in good shape but I have a play in one of the cables of my second cylinder so I really just have to change one pin... Buying a used one doesn't really feel right since I have to wait for it like 3 weeks when I order something from the States. :)
RCO
Those are also used by GM/Delphi on automotive applications. They call them "Weatherpack" connectors. Can probably find the right one from a good auto parts store for under $15.
