Hello fellow boaters!
I have a boat with Force L-drive, 1990, 120 HP motor with seized up lower unit that has been sitting in my back yard for about 8 years. It used to be running pretty good until the lower unit went out. After all this time I decided to get a rebuilt lower unit and get the boat running again.
The motor was not winterized when I brought it home the last time (8 years ago). I'm looking for some tips on what to do before I try to start it?
Should I take out the old spark plugs and spray oil (fogging oil or sea foam?) inside on each cylinder and rotate them by hand? What else? I want to see if the motor runs before I spend money on the lower unit. Some of you might suggest to get rid of this boat/motor, but I only have about $2000 budget for this and the lower unit is around $1600. So, any tips/advise are greatly appreciated! Or, what problems could I run into after its been sitting for that long outside (the boat was covered, but it is Minnesota and we get -20 in the winter
