Looking to purchase a 1993 17' Crestliner with Volvo 230 4 cylinder and SP drive.
broncojeff78
Hello everyone. I am looking to purchase the above mentioned boat sometime this week. The boat has been well cared for as it doesnt look weathered at all! I have never had a Volvo Penta setup before and was wondering if this a good unit to have or not. The marina said it was a 3.0 GM block with all the Volvo stuff on it. According the the VP website it is a 230B. Any insight would be great as the boat is beautiful and priced right i'm just unfamiliar with the drive/engine. Thanks!
Maclin
If it is a Volvo Penta AQ230B then we know it is NOT a 3.0 GM block :)
Those engines have closed cooling, meaning engine coolant/antifreeze flows thru a 2 chamber heat exchanger and raw water from the lake flows thru the other chamber to keep the engine cool. All of that is a good thing because raw lake or sea water will corrode the aluminum heads quickly. Also with closed cooling the engine can run a little hotter and maintain good combustion efficiency. Slightly easier to winterize also. The engine is based on a Volvo automotive block but there are differences, I do not know the specifics there, sorry.
As with any older machinery, prior maintenance is paramount. There are specific maintenance procedures, all from the Volvo Penta operator's manual for the AQ230. If no shortcuts were taken then that will be a good setup. Those drives are very stout and maintenance items are simple enough for the mechanically inclined. Parts are sill available for that vintage of drive. Changing the impeller for the raw water pump, a 2 year maintenance item, is easy because the pump is on the front of the engine. On Mercs and others the outdrive has to be taken apart, just one thing that is simpler with a VP.
If you are not inclined that way and need to depend on a shop to take care of things then look and call around to see if any shops close to you are VP shops, but make sure they know the older "white drive" units as they are way different than the current VP units. Along this train of thought, be wary of the "marina" that said it is a 3.0 GM. You did not say what role the peson played at the marina, if a sales person then OK, but the 3.0 block comment indicates a sad lack of knowledge for that boat's driveline.
broncojeff78
Thanks for the response Maclin. The boat is at a marina on consignment and i was told this by the sales lady there. She sounded like she knew what she was talking about but more likely a good salesperson needs to sound like that.....truth or not. Judging by the rest of the boat being way above average condition compared to other mid 90's boats i've looked at recently I would think it would have been maintained properly. I'm no stranger to out drive repair, just dont care to do it often after rebuilding my last alpha 1 last summer. Here is a pic of the engine.
