Looking to re-do 1986 Bayliner
bigboistoy
I want to re-do all of the interior of my 1986 22ft open-bow bayliner. I think that the wood should be replaced and want new carpet and vinyl. Does anyone know where to start? Everything is so weathered and cracking. The carpet is ripped and my wood is exposed.
proshadetree
Re: Looking to re-do 1986 Bayliner
Any soft spots in the floor? How is your transom? A boat that old should be checked carefully. If core samples check good I would replace the carpet. Then Redo the wood for the seats and side panels. Coat well with a good paint or resin. I use resin. I also reused all my foam. Got some pics? Love the Bayliners.
saltwaterbluefish
The first thing to do is make a budget and say I will spend this much to redo it. Then make a list of what you are going to replace. For example: I need 10 yards of carpet, 5 yards of vinyl, two new seats. Before ordering go ahead and check out the rest of the boat. Just like proshadetree suggested, soft spots in the floor, if the transom sounds hollow, and go underneath the boat if it is on a trailer and see if there are any stress cracks (sign of rotted stringer). Online stores usually have vinyl and carpet at prices about half of what you would find elsewhere. For the wood I am not sure which wood you are talking about. If it wood used for trim make sure it is the right type of wood or you will be doing this again very soon. White oak and teak are the ones usually used, but I have seen in some cases people use pressure treated lumber and then stain it to look like another type of wood (Ship Shape TV idea).
bigboistoy
I will take some pictures and post today. The spots in the wood are the floor but the bottom of the boat is fine no cracks and no leaks so the fiberglass is fine just the wood.
bigboistoy
Thanks! For your help! I will take pics and post later on!
