I've asked in other posts awhile ago but never really got a straight answer, my 1970 60hp johnson is getting water in the lower unit (about an ounce while it was in the water for about 7 hours).
I am wondering exactly which seals could be failing. When I try to do a pressure test, it won't even build up pressure (can hear hissing inside the LU).
I'm assuming it could be the prop shaft seals (two of them) or the drive shaft seals (two of them?). The drain/fill plugs and washers are new so I know it's not them.
Are there any other seals on this particular motor that could be causing water to get in? Also are there any special tools needed to replace any of these seals? I am relatively mechanically inclined and I do have a manual (not the most helpful). I am hoping I can replace the seals myself.
If anyone wants to give me a rough estimate of what you think a shop would charge to do it, that would be cool. My step dad just had his older evinrude worked on (carbs rebuilt and a few other things) by a guy who does good work. He charged 280 bucks.
The motor otherwise runs great and shifts great.
Thanks
Thanks
