Looper 120 wiring diagram
Budget33
Hi All,
Let me first start off by saying Hello to everyone as I'm a newb.
My problem is I need a wiring diagram for my Looper 120, was told it was a 1986 I havent seen the serial number and model number plate, not on the transom clamp.
I need the diagram because there seems to be no power at the controls, turn the key and the engine doesnt turn over, same with the trim switch. There IS power at the starter because I can cross it and the engine turns over. If I unplug the trim wires I can manually power the motor.
Thanks for the help,
Budget
boobie
Re: Looper 120 wiring diagram
Go to the top secret files at the beginning of this forum and look for wiring diagrams. You may get some ideas.
Budget33
Thanks all, it was the master fuse, thinking about converting it from a glass fuse to a new blade type
