Re: Looper, Crossflow, what are they?
The most visible difference is the top of the pistons.In a looper the top is flat,while in a crossflow one side of the piston is higher then the other.
A 2 stroke has its exhaust stroke and intake stroke at the same time.While exhaust leaves the cylinder,fresh mix comes into the cylinder
A cross flow typically has one intake and one outlet port at the bottom of the cylinder.Because of the height difference of the piston top,the fresh fuel mix is directed upward toward the sparkplug while the exhaust gasses leave the cylinder.
This system is a bit wasteful because part of the fresh fuel will get sucked out along with the exhaust gas without ever having been ignited.
A looper is a product of the seventies. Instead of one intake,there are several in the cylinder wall.They are placed strategically so that the upward stroke will concentrate the fuel mix close to the spark center.this makes for better fuel use.On the down stroke there is still some fresh fuel loss,but the exhaust is built in a way that it sends a sound wave that causes a push back into the cylinder of the fuel mix that would otherwise be lost.
The flat piston head is just part of this looper design.
I am sure that others can explain it much better,but I hope that this helps.
Johnson evinrude started with loopers in 1969,while Mercury likes cross flow better.
Hit this website and see what a crossflow does:
http://www.animatedengines.com/twostroke.shtml
now see a looper.
http://en.wikipedia.org/wiki/File:Arbeitsweise_Zweitakt.gif
