Re: looping idle
Sounds like you've got the old quadrajet, and I just went through this whole thing myself. With the engine idling, take a look down the carb throat. You shouldn't see any gas dribbling out of the jet. If you do (like I did), you've got a carb issue. I took mine apart and noticed a couple of things. For one, the needle valve had come completely out of it's seat, causing an extreme rich and flooding condition, and secondly, the screws holding the base to the throttle body were loose. I soaked everything in carb cleaner overnight, blew it out real well, and reassembled it. Idles much better now. As long as your gaskets are OK, and your needle doesn't show any wear, you shouldn't need a rebuild kit. Good luck!
