loose bolt alfa one
scallywag
just found a loose bolt on my alfa one leg. it is one on the lower unit where the leg splits.one or two mm not hanging right off.could this cause me any problems.
trevorcday
Re: loose bolt alfa one
Depending on which of the bolts is broken it could cause lots of trouble. One possibility is that you lose the gear oil out of the upper gearcase and seize it. Also, since these bolts carry all of the thrust that your drive creates you could overload the remaining bolts and lose your drive. My recommendation is to fix it.
