Loose hinge pins on gimbal ring. How much can I get away with?
Homerr
I have a Alpha gimbal assembly that has some slop in the gimbal ring. The hinge pins look fairly new, and I'm told the bell housing was recently replaced, as it looks new.<br /><br />I would say there is approx. .005" to .010" slop when you move the bell and watch the pins. In other words, you can see the bell move a bit sideways within the gimbal ring.<br /><br />I'm sure I can get away with this for some time, but as I need to replace bellows and such, should I worry about replacing the ring?<br /><br />Can I get oversized pins or a sleeve?<br /><br />Thanks,<br /><br />H.
