Loose steering 200 Yamaha
robalo2160
I've got a 2003 200 HP Yamaha outboard on a 21 foot 1993 Robalo, and the hydraulic steering is awfully loose. To move the motor from full deflection on one side to full deflection on the other side yakes 5-6 full turns of the wheel. While cruising, if I want to make a 10 degree heading change, I may need to turn the wheel 1/2 to 3/4 turn, then the boat may jump 30 degrees. After which, I swing the wheel 1-2 turns in the opposite direction, and the boat swings 20 degrees back. What's going on here? :confused:
Dhadley
Re: Loose steering 200 Yamaha
When you turn the wheel while under way does the motor move as you move the wheel or do you turn the wheel a 1/2 turn and then the motor moves?
Sounds like it's Air-bound,+ Needs to be Bled........
robalo2160
Originally posted by Dhadley:<br /> When you turn the wheel while under way does the motor move as you move the wheel or do you turn the wheel a 1/2 turn and then the motor moves?
The motor does not always move with the wheel. The motor catches every 1/2 to every 3/4 turn, then jumps a bit.<br /><br />J Dub
Dhadley
Sounds like it may be low on fluid. Another thing comes to mind but lets hope it's something simple.<br /><br />Be sure to use only the aircraft grade fluid recommended if it is low.
robalo2160
what is 'aircraft grade'? Can I pick this up at a reputable marine supply store?
