Re: loose steering wheel 87 bayliner capri 16
a tilt wheel is like a lock on your steering column .... it you had tilt....you would know it.
inder the bezel or flange of the wheel there is three bolts.....they will go thru to the under side of the dash. tighten up those bolts.... if the wheel still has play......replace the system.
