Re: Lose power at WOT
You may want to check/replace the fuel pump diaphragm (app. a $6 fix). Sounds like you are getting a vacuum leak somewhere. All it takes is a small pinhole. Also, if you have a built in tank, the anti-siphon valve could be causing the problem. I had the same thing happening with my 75 1500 and I had to rebuild the fuel pump and replace the anti-siphon valve with a standard fuel fitting. If you have an inline filter, replace that as well. <br /><br />Also, like Tim said, run a portable tank (if you have a built in one) to see if the problem still occurs. If it does, you know that the problem is in the fuel delivery. Good luck!
