loses power at high speeds
huttoboy
I have a 1993 Johnson 115 Model TJ115TLETS that I bought new and has few hours on it. I started experiencing a problem where it would run OK for a while then lose power when I went to throttle up. Starts and idles good. Used Clymer manual and checked fuel system, stator, pwr pk, coils, spark @1/2" all seem good. Noticed "clean" plug in #4 and evidence of water in cylinder. Any suggestions on what to look for and how easy is this to fix?
tashasdaddy
Re: loses power at high speeds
first do a compression check, hopefully it's just a gasket.
huttoboy
forgot to mention I checked compression. That cylinder is the lowest Port side 117/100 <br />Starboard side 120/120, rounding off<br />My Siberian's name is Takoda (means friend-to-all in Lakota language)
tashasdaddy
someone with more expertise will be around. i suggest getting an OEM manual, engine specific. kencook.com.. i thrown all my Clymers away, can be very vague. seloc are better than clymer imho
huttoboy
Thanks Tashasdaddy<br />Just for grins I pulled the head on that side and found the cylinder full of white milky water/gas/oil. <br />the head gasket has "holes" in it near the edge of the #4 cylinder wall. The water jacket has lots of calcium build up too. If I replace the head gasket on that side is it wise to replace the other one also or leave as is due to the compression test being good?
huttoboy
To follow up: The best I can tell is that the whole problem is a Port side head gasket. I ordered a complete set of head and cover gasket.. Should both head gaskets be changed at the same time or is Starboard side OK if the compression results are good and have had no other problems on that side?
tashasdaddy
i would do both sides while you are at it. this way you can check the other side. you've already bouhgt the gaskets. if you are like me and leave them laying around they will be ruined, when you need it.
huttoboy
May be a dumb question but the repair manual recommends to put OMC gasket sealing compound on the head gaskets. Can't get OMC around here but Permatex 1 & 2 are available. What should I use since I'm new at this head gasket thing? I do have torque wrenches available in both inch/pounds and foot/pounds. Thanks for your advice, Tashasdaddy.
Cricket Too
Did you see any scoring on that cylinder wall from lackof lubrication? Also, I would clean out that calcium buildup while your at it and replace the delfectors in the cooling passages, if there is any.
huttoboy
There was no evidence of scoring in that cylinder and, yes, I have cleaned out the calcium.
