LTC Birkett
- Joined
- Sep 1, 2003
- 18
Thought I would post a question here and continue trying to figure out why (actually I think I know the why...) and come up with a solution to allow my FF to continue reading the bottom (depth) while my boat is on plane.<br /><br />I have a two month old 2005 PT175 with 75hp Merc. Everything works wonderful but I get nervous planing on unfamiliar water without knowing where the bottom is... I have lowered the stock Lowrance x-37ex transducer bracket as far as it will go.<br /><br />When I eyeball the line from the transducer to the bottom of the hull (this PT175 has a stepped hull) it apears to me the transducer loses clean water while the boat is on plane. At this point all I can think of doing is dropping the transducer down lower using some homemade McGyver brackets.<br /><br />Would really appreciate and thoughts and suggestions on this issue and how I might regain contact with da bottom.<br /><br />Thanks in advance for your time and sharing your experiences with this new boater.<br /><br />tight Lines,<br />Bill
