losing power at WOT
tshamp1957
I have a 1981 Mercury Marathon 135hp outboard. At WOT it runs fine for a short distance, then bogs down. If I let it sit a few seconds, I can open it up again, but then the same thing happens. Any ideas? I have rebuilt carbs, fuel pump, replaced primer bulb with OEM, and changed out all fuel lines. Still the same problem. Can someone help me please.
jimmbo
Hmm. well first of all, there was no 135 hp in 1981. Is it an inline 6 or a V6?
1970 - 71 inline6
1986 and newer V6
As for it being a 'Marathon', Mariner used that name on some of its engines.
As for your problem... Portable fuel tank, or built in tank? Have you tried running it with different tank?
tshamp1957
It is a V6. I'm sorry it is a 1986. It is basically a built in tank. I have not tried running it on another tank.
jimmbo
You replaced some fuel line components. Did you pull the fuel pickup out of the tank to inspect it for blockage? Some pickups have a filter to stop dirt/water from entering the lines.
jimmbo
You're sure that was the fuel pickup tube and not the tank vent?
tshamp1957
Yes I' sure. On the right side of the tank is the fill tube and vent tube. On the left side is the sending unit and the pickup tube.
tshamp1957
OK Jimmbo, I disconnected the fitting at the engine from the fuel line and capped it off. I pump the primer bulb (Brand new OMC) and it gets hard and then loses the pressure after about 30 seconds. I used soapy water on all fittings to check for leaks and found nothing. Any ideas, and yes I have the arrow on the bulb pointing skyward.
Chris1956
Does the primer bulb collapse,when the motor starves for fuel? If so, the fuel tank vent could be partially clogged. Also, most fuel tanks have an antisiphon valve. These can get partially clogged as well.
The primer bulb loosing it prime after 30 seconds is NOT an indication of a problem or external leak.-----The bulb is a manual pump to fill the carburetors and once that is done it does nothing.
tshamp1957
Roger that racerone. So do you have any suggestions as to why it runs at WOT for a bit then bogs down. After setting a bit it goes good again then bogs down. It is as if the carbs empty out then refill. They have been rebuilt and so has the fuel pump.
jimmbo
There plenty of places in a fuel system where a restriction or an air leak can happen. Both can result is fuel starvation
