Hello all, kinda new to this forum, but it looks like the right place to get some help. My friend and I recently bought my grandfather's boat from him. It is a 16' starcraft with a 70 HP Chrysler outboard on it. He mentioned to us that if you held it pinned on full throttle, it wouldn't run very well, but if you backed it off just a tad, it would. Well, unfortunately, on full throttle, the boat didn't seem to have a whole lot of jam to begin with (Not nearly what you would expect from a 70), and backing it off would just make her wobble between plane and coming off plane (Boat unstable-not good!) So, my friend is a heavy duty mechanic (not to be confused with a marine mechanic
hehe, and he decided he was going to fix it. Well, long story short, but essentially, 2 hours later, we could actually start the motor again. Anyway, what we found now was that, if he held the throttle cable on the motor itself, that boat would go like greased lightning (We are talking fast here-no speedo, but lets just say the hole shot lasted about 2 seconds between 0 and full speed). It would run absolutely wonderful like this all day long (As long as he held the throttle linkage at the motor). If he let go, it would act like it was going to stall (although it never would), and it would also idle absolutely perfect. Now, he said he checked the fuel lines-says they are staying hard, and he tried to adjust a few other things (Yes, he got around to the timing, and no timing light-we found out how to troll back the 14 km's we had travelled on the 4.5 hp kicker). So, upshot of this long story is-has anyone had this happen to them, and if so, what did you do to resolve it? The points are this: Starts perfectly-no sputtering or backfires, Idles like a dream (all day long if you want, no problems), Builds power part way through the hole shot without a hitch, then starts to hiccup and acts like it's being starved (Also, there is a distinct smell of unburned gas when the covers off. My friend believes it might be a timing issue, but isn't a marine mechanic (I think Cat engines and outboards might be a little different). Any help would be greatly appreciated. Thanks in advance.
