losing reverse on my '71 evinrude sportfisher I/O
mk_bovee
last night i took the boat out for a little fishing trip to one of our local bays here in MI. after getting the boat off the trailer, i tried to put it in reverse to back away from the launch dock, but it kept killing the engine as soon as i hit the reverse switch. the week prior i had it out without any troubles, so it is a new problem for me.
any suggestions as to what teh problem and any fixes may be?
Re: losing reverse on my '71 evinrude sportfisher I/O
Ayuh,...What Motor,..?? What Drive,..??
mk_bovee
it has the I-4 120 HP, and im not sure what the outdrive is, but it says sterndrive on the top of it. maybe if i post a pic of the drive you can identify it.
Howard Sterndrive
killing engine sounds like bearings in the outdrive packed it in.
Drain all 3 drive oil compartments and see which one's oil is full of grey metallic chunks....
Also could be the electrical load of a shorted reverse coil resulting in the ignition cutting out due to a drop in system voltage.
