I need help, I have a 1994 195 sundowner with a 5.0 litre V8, carburated. I have been losing RPM's on the engine. it should run 4000 to 4400 per engine specs. I may get 3600 out of it. The boat brand new came with a 19 pitch prop, ran fine. I had mechanic look at it. He put a 17 pitch prop, kind of cured it, but still only get maybe 3800. Compression has been checked, fine. carb has been rebuilt. Still runs low.... what can be the problem? I have read that a "coil" could cause the loss in RPM's? is this true? what checks am I missing to find the problem? Also. the boat specs call for a 19 pitch prop for boat. I believe mechanic was just dropping down to pick up the RPM's. pleas help
