Losing spark on all cylinders around 2800 RPM?
sptjet90Reflexx
engine on muffs in driveway, remove throttle cable and manually advancing throttle. 2800 RPM los​e spark on all 4 cylinders and then some of them will randomly return but it will skip like crazy then it will throttle up past it but I still don't have spark on 1 or 3, what could cause this? I even tried putting the old trigger back on and it made no change.
New stator, trigger and switchbox all replaced at the same time. Also has a new fuel pump, carbs and lines cleaned and replaced.
