Was cruisin the lake this memorial day weekend for about an hour and half. Boat running fine. On way back to marina motor lost power and eventually died. I could start motor and would run in idle only. No overtemp. alarms. I recently fixed that problem by replacing thermostat and impeller. Used boat two other occasions after that and had no problems until now. What could this be?
I also found a lot of trash in my fuel filter. Also pumped fuel into container with bulb valve and had some trash coming through. i am wondering if my fuel tank needs cleaned out.
