nabeel.alsalam
- Joined
- Jan 4, 2005
- 37
I was in a sailboat regatta last weekend and I lent my boat to the race committee to use as a rescue boat. <br /><br />While they had it two things happened to my 1991 Johnson 40 hp engine. <br /><br />First, while on a plane it suddenly lost most of its power and would only run at a 1800-2000 rpm with WOT. It idles OK although a bit slower than it was before (750 vs. 1000 rpm in neutral). <br /><br />Second, the engine is now making a mild and steady clacking sound that wasn't there before. <br /><br />From searching previous posts on this forum, the most likely reason for sudden loss of power seems to be crude clogging the high speed orifice or passages. Correct? So although I'm surprised stuff can get past the in-line OMC filter (which I admit I have not changed recently) and althouggh I just rebuilt the carbs a few weeks ago, I guess I'll at least try removing the drain plug from the two carbs and the main jet orifice behind each. <br /><br />Any thoughts on what might have happened and what I might do to narrow down the possibilities? Thanks.
