LunkerClassic
- Joined
- Jul 21, 2007
- 6
I recently noticed a sudden loss of power in my '82 50HP mercury. It idles fine and retains about 15-20% of power when at full throttle in both forward and reverse. I pulled the plugs and noticed 3 of the 4 had a significant carbon buildup, much of it looking wet. Some of the wires also had slight corrosion on the terminals. I'm very anal about the 50:1 mix and am wondering if this is the likely problem. Do I need a different brand plug or one that burns hotter? Or should I go with less than 50:1 oil? I use NGK BUHW-2 plugs. I'm a building contractor and am handy but admit to being a relative novice with engines. Any input would be appreciated as fishing opener is around the bend.
Thanks,
Aaron
Thanks,
Aaron
