Loss of power only around 3500 RPMs, pumping primer bulb relieves it
tomfsu
My 2001 Mercury 125hp motor starts losing power (slowly starts to drop rpms) after about 5 minutes of cruising around 3500 rpms . Once this starts to happen and I pump the primer bulb it quickly regains power and cruises at normal speed.
It cruises at WOT and almost any other rpm level with no problems, no hesitation. I replaced the in-line fuel filter and disconnected the fuel line and placed it directly into a portable tank. The engine is still having the same problems. Any help or ideas would be appreciated.
Thanks,
Tom
Laddies
Banned
Re: Loss of power only around 3500 RPMs, pumping primer bulb relieves it
Sounds like the fuel pump is going bad.
CharlieB
Or possibly a small air leak INTO the fuel line between the fuel supply and the fuel pump.
Check every connection in the hoses between those two.
Test by temporarily adding a section of clear hose between the fuel pump and carbs, watch for any 'air bubbles' which prove the presence of a leak.
hkeiner
The below Mercury advisory may help with checking the fuel supply system. If these tests do not indicate a problem with the fuel pump or fuel lines, I would next suspect gummed up carbs. The motor may be regaining power when you squeeze the fuel bulb because the increased pressure is overcoming a restriction in a gummed up passageway. I've seen that happen before.
As an alternative, instead of doing a lot of troubleshooting stuff, simply rebuild the fuel pump and clean the carbs and see what happens. There is a very good chance the problem will go away and these steps are periodic maintentance items anyway. I think that your portable tank test pretty much eliminated a possible problem with the fuel line upstream of the fuel pump.
Just my thoughts....
tomfsu
This is great information, thank you all for the insight. I will let you know what happens.
j_martin
Whatever you do, don't run it like that. It's a good way to burn a piston.
hope it helps
John
