OK, I have checked all there is to check on my 1996 90 hp SPL Evinrude. I have since replaced 1 power pack because cylinders 2 & 3 had either no volts or sporadic volts, replaced the fuel/water separator, looked at all the fuel lines for leaks or looseness, did a quick check of the carbs for leaks plugged orifices ets. I even did the run the engine and pump the ball thing and nothing fixes the power short. I am just wandering how I can go from 45mph at 4500 RPM to 35 at a 4500 RPM after sitting for only a few months?? So far I have established that the check engine light that use to come on sporadically stays on all the time now, since I have replaced the power pack!(WHY) All my cylinders have around a 130 psi. All I want is my power back! I can just tell running at WOT that it is not running the way it was a few months ago. The engine also sneezes alot when I start it cold. Hope you all can help thanks
