Re: loss of power
Your mix is right.Have you checked your spark and compression.You might only be running on one bank(side).You can check spark by removing all plugs,and place a plug in the plug wore ,hold it away from a good ground on the engine,I like to sandpaper a head bolt til it shows metal,one by one check to see if you have spark.You can by cheap compression gauges at local discount auto store for about 20 bucks,its a great tool to have forever for any engine,check compression and write them down. should not be big differance if 10-15 psi.If these checks are good,perhaps you have dirty carbs,but you say they are wet,are they ALL wet.
