While running back to the ramp with my 1975 model 50 hp Evinrude twin cylinder RPM's slowed and after reducing power a knock was heard in the engine. After pulling plugs and checking compression the top cylinder indicated 145 lbs and the bottom indicated 115 lbs. Any thoughts about bearing or piston damage. The engine may have run up to 5300 RPM at times (seldom) and gas/oil mix is always 50-1. Columbia River spring chinook season is peaking and the fish cooler stay empty with the boat parked.<br /><br />Thanks
