So i took the boat out last weekend. After a full day of tubing and cruising, was on my way back to the dock and heard a clunking sound. Put it in nuetral and wemt away, was very busy on the water so i tried to get it in gear to go to the shore... The clunking started again ( not from motor) and when almost there lost propultion either way. Clunking stopped motor still running...
Pulled boat out ( got a tow) and got it home. Suspected low fluid in o/d and assumed blew the gears. Fluid level ( when drained) was fine. A little wattery at first coming out. Didnt see any big metal chunks. O/d still locks with the motor off and control engaged f or r.
Havent pulled and inspected imternals on o/ d yet, wondering what you all suggest / suspect... Drive shaft issue??
Let me know if any additional info will help...
Thanks for amy help / guidance!
Cheers
~JR
Cheers
~JR
