I have an 86 Bomber Bass Boat, with a 110 Johnson motor. Early in the year, I was having problems keeping it running at idle, and brought in for repair. Turns out I had water in the cylinders and had head gasket, water pump, thermostats, plugs replaced. Also pulled powerhead to inspect for damage and replaced gasket.
Took the boat out for test drive and seemed to run OK, then hit a stump and spun the prop early, so didn't get much chance to fully test. Before the repair, I was getting 5500 rpm and 45 mph with a Propco 13 x 19.
Went to the marina and they only sold OEM props, so ordered 13.25 x 19, which only gave me 4700 rpm and 42 mph. Exchanged (at the direction of marina) for OEM 13.5 x 15, which gave me 5800+ rpm (didn't open up all the way) and 35 mph. Exchanged again for OEM 13.25 x 17, and only got 4700 rpm and 41 mph. Ordered another Propco 13 x 19, and still only getting 4700 rpm and 41 mph.
It seems as though the motor has lost power, as with all but the 13.5 x 15 prop, it struggles to come up on plane. Even when replaced with the same prop, it does not perform like it used to.
I'm not sure what could be causing the loss of power, but started by pulling the plugs to see how they looked. I noticed the plugs they put in were Champion VL77V that do not have a side electrode. Could it be the plugs that are causing the lost power?
I am only a novice when it comes to analyzing or repairing a motor, but with a little help, from the veterans on this board, I'm hoping to get better. As I've read through numerous posts, there are a lot of experts who have provided great information to novices like me. Any help is greatly appreciated!
