lost yamaha ignition key ? how to tell which one to order
985johnm
I bought a 115 yamaha 2 stroke 1987 model the original owner didn't know where the key was. I looked on the sight there must be 10 different keys there. how can i tell which one to order?
robert graham
Re: lost yamaha ignition key ? how to tell which one to order
At the key switch, remove that little black rubber grommet, then remove the hex nut that holds the switch in place, look right in there behind where the hex nut was for some numbers, and they are the code numbers to order your new key. Good Luck!:)
