timmeraw
- Joined
- Jun 10, 2008
- 258
Even though I have lots of experience restoring these 4 cyl Mercs I am running out of ideas here on this 1972 Merc 50 with lightening energizer ignition. It has great spark on all 4? it has good compression(actually I have only checked the top two holes now that I think of it). Somebody had been playing with the timing stops and trigger throttle advance arm so using a timing light I did the link n sync per specs. Battery is good and cranking well. Fuel is fine(same tank I use for other motors I am working on). Carbs removed and cleaned (weren?t very dirty actually). Floats/needles/seats are working as I can pump till hard.
Problem is I cannot get it to fire up and run. With premix in the the holes I have had it pop once or twice but will not run. I am stumped. With spark this good it should at least consistently rumble for a second or two burning off the premix in the cyls. This is why I thought it might be a timing issue and set it all up correctly(including of course getting the distributer pulley arrow lined up with TDC mark on flywheel). One thing I should have checked?especially with the distributor off was if the plug wires were actually connected to the rotor cap correctly? I should have also checked the reeds when I had the carbs off come to think of it.
Any thoughts?
Any thoughts?
