Re: Love your fishing boat? Tell me why
I owned a 13 foot Sylvan Alaskan Deluxe several years ago. Smokercraft is the same company and the exact same boat.
I would agree with the other poster as to only good for actually I say only 2 people. Problem with the small boats is their max HP ratings. The bottoms real estate (for lack of the correct term) are just too small for the larger motors hence the low max ratings.
They look really nice. Real high sides to keep out the waves (that's why I bought mine). But they are classified as utility boats. Basically, a rowboat that you can put an outboard on.
Mine was rated for a 25. The 15 footer is only 35 hp. If I went and bought the max O/B the rating, the max is like 600lbs for everything motor, gear etc Add a 3rd person and you are very close to the limit which is getting close to becoming dangerously unstable.
Worse yet is most are tillers (driver at the back) and the battery and gas tank are back there too. With the max O/B on there the water line is going to be only inches from the back of the transom. They are so basic they don't have that splash tray in the back to catch a wave that might wash over the transom and drain back out the hole, if a boat flys by behind you. They don't have bailing pumps installed.
I couldn't get rid of it fast enough after one season. Sure they sell fast. First guy that saw it grabbed it off Craigslist.
But there is a reason why they are so cheap, because most are just fancy rowboats. My advice is to not go less than a 16-17 footer if possible and buy a real aluminum boat that can be bought as a package boat, motor and trailer for 7-8k (Like an Alumacraft 145). Or buy a similar rig used for a few thousand less than you would pay for a new Alaskan.
Check out the max ratings on the Alaskan line below:
http://sylvanmarine.com/showroom/default.aspx?typeid=2&seriesid=53
