Low Charging, possibly incorrect wiring?
lent0n
1975 evinrude 75hp, bought from a mechanic who did a lot of great work with it.
Starts, runs, all the good stuff no issue,
My dash voltmeter and USB charging both show around 12.9V-13V for charge while at WOT.
I don't have a tach to verify the RPMs at this stage.
I swapped the rectifier since Amazon has them on next day shipping with no change.
I noticed on the bus bar that the one of the yellow rectifier leads doesn't go to anything, I believe this should be connected to one of the other stator leads.
Photos won't upload but I think this might be as simple as moving that other lead onto the other stator output line
Crosbyman
2 yellows (AC) normal go to the rectifier to become DC or regulated DC if you have a rectifier-regulator to give you flat DC
lent0n
Yeah that's what I'm saying, but on looking at the setup a second time, I see that the second rectifier contact is bridged over to the other stator wire. I'll double check that there's continuity but doesn't seem to answer any questions. Really hoping it's not the stator because it's just an expensive part.
saltchuckmatt
Changed it because $25 on amazon is cheaper/faster than testing it. Still getting 12.9-13V.
I hate to tell you but that's about all you get which is enough really. I'd put the old OEM back on.
I could test that rectifier in about 5 minutes.
New 4 strokes are getting 14.5 but not older 70's....just sayin
lent0n
That's actually great news, my fear is a melted stator which I experienced last summer from a poor rectifier connection which is why I'm much more paranoid about it. I don't run a ton of stuff, speedo, voltmeter, small stereo, eventually a tach and all only while running really just keeping LED lights on. My old motor where I had my voltmeter hooked up was a johnson 90s 70hp and it put out around 13.5v, but it had a modern regulator/rectifier setup. I'm not really that picky just wanting to avoid a costly part swap that would be easy to resolve now.
What's your steps to testing rectifiers/stators? I just want something I can use in the future.
lent0n
