Low compression 1984 Mercury
HTG
I have a 1984 35hp Mercury that i am going to be testing the compression on soon. Are there any videos, articles or threads on this site that explain what to check and how to fix low compression?
jimmbo
Re: Low compression 1984 Mercury
Checking is not difficult. with engine warm, spark plugs out, throttle open. pull starter 3 or 4 times tilll gauge stops rising, or use electric starter. If cylinders are not within 15lbs of each other there is a problem. Could be as simple as sticky rings(usually easy to fix using a combustion chamber cleaner) up to and including broken rings, scored cylinders/pistons(require complete teardown of power head)
