outboard is new to me. did compression test today. #1 and #3 have about 135 psi while #2 has only 40. looked inside the cylinders with an inspection camera, pics are from #2, not sure what to make of these, scores/scratches? All 3 cylinders have vertical lines.
i guess next step is to pull the head and take a closer look ? i have a service manual. Anything/gotchas i should watch out for during the process?
also, when i primed the fuel tank bulb, fuel leaks out of this hole in the bottom carb, what would cause that? will it carb rebuild fix it?
thanks.
thanks.
