Low hours on CL....
25thmustang
Re: Low hours on CL....
Low hours can be a positive or a negetive in my opinion.
Motors and their associated systems need to have use every season. With that said overuse and abuse can cause issues as well.
A now 8+ year old boat with 45 hours, means less than 6 hours a year, assuming it was launched every year. I know in just two day trips I have gone 5-6 hours.
sheridon
I have only had my boat just over a month and have over 20 hours on the motor....
Guess the owner like hanging out at the dock??
Fireman431
As someone who bought a low hours, larger boat (6 years/90 hours) I can tell you that there are a lot of them out there. People buy them and have big plans on using them, but never do. They go to the marina, run the engines and generator for 15 minutes and hang out at the dock. Maybe a fear of breaking their new toy? No confidence? Fuel costs? Whatever reason, they don't get used.
What you have to look for is the overall condition of the boat. Chances are there has been no engine maintenance (i.e. impellers, belts, hoses, oil, etc). these are the parts that die from lack of use. Age, not just use, plays a toll on rubber parts.
To get a true history, have a marine survey done. They can put the scanner on the engine ECM and tell you how many total run time, max temp reached, max RPM, engine fault codes, etc. The hour meter could have been replaced a year ago.
If you get the boat, do a tune up including plugs, cap, rotor, fluids, belt, and impellers. If it truly has low hours...SCORE!
180shabah
I assume at $70000 there will be a survey involved, that should answer any question. The hours alone would not scare me. When I purshased mine, it was 9 years old with 33 hours on it. Unique case though and the "story" was verifiable.
Why do stupid people breed?
Seemed like a good idea at the time :D
