snookhooked
- Joined
- Aug 19, 2008
- 159
Hello, I have a problem with idling. it will run and sometime dies eithr on its own or when I put it into gear. it kinda jerks/rough idle. I took all the carbs off one at a time and thoroughly cleaned them with carb clean and air so I am pretty much sure upon looking that they are cleaned. I didn't mess with the throttle plate they are attached to thinking they didn't need to. I have 1992 150 spitfire Evinrude motor number ELENCE. the carbs attach to the throttle body if I am saying that correctly? two of the carbs were making a spitting sound ( they were on the same side) before I cleaned them and now the bottom on on the starter side is still making the same noise but only when you idle up the motor. it runs better but still have some rough idle there but way less than what it was. I also sprayed and blew out the throttle body with the screens still in place. the only thing I can guess is maybe where the gas enters the carbs through the throttle body still has maybe some blockage or I have some type of air leak I haven't found. I am just confused to what I need to do to correct this problem? maybe somebody has has this experience with this motor that knows what to look for and how to solve the problem. I know I have cured some of it since it is starting up some much better but I haven't completely solved my problem yet.
. its a great motor but is driving me crazy at the same time lol. any help would be great. Thanks
