1991 Fastrike 150hp serial # G02956027 rough idle and lately seems to be loading up at low rpm's had a compression check done all between 85 and 90 a little low but was told that it is still got plenty of hours to go WOT is great 60mph by gps doesn't skip a beat but low end she isn't as fast out of the hole and it bogs when puttin it on the trailer and seems to be a little rich .plugs where wet 3 of them when pulled.What do you think I should try one guy mentioned a gasket on the side of the carb under a plate with 4 screws that might cure it >>> help
