Re: Low Oil Warning
That's the no oil alarm .Inspect the oil line to and from vro pump for leaks.Is the oil reservoir primer bulb firm?Inspect oil reservoir for proper level,check for contaminates in oil reservoir,check/clean pickup in oil reservoir.Inspect the oil reservoir tank vent.If the tank won't vent ,the oil won't flow.May just be that your vro pump is getting tired.Don't take that rapid alarm lightly or engine damage will insue.It's not a failsafe.If it were my recently rebuilt engine and I wanted to maintain the vro feature ,I would upgrade to a new four wire vro ,particularly if the one you are running is the original.In any case ,check the above items and make sure that you are getting a clear ,unobstructed ,air free,and leak free oil supply from reservoir to inlet of vro pump.The only way to assure this is by disconnecting the oil inlet to pump and priming the oil line until a clear flow of oil is present.Reconnect oil line securely.It is then recommended that you mix 50:1 TCW3 oil in you fuel until you can establish oil usage from reservoir.Do this by marking a line on the side of the resrvoir at and below the oil level.Test run for results.
