Low pressure question
anthony7
I can get a 1981 Sea Ray 20' for $800. The boat itself is in great shape the only problem is that the 2 cylinder v8 has low compression in both its cylinders. Anyone know how much this might cost to fix?
proshadetree
Re: Low pressure question
Do what? A 2 cylinder v8 with a compression leak in 2 different cylinders?
Ayuh,... Whatever is costs to replace the motor,.... Or less...
S. Toth
still, for 800 you get a boat, trailer, motor, even with the low compression which you could still run her with it. So your able to still use it, but you basically will probably need a new motor:(. Anyway your getting a deal for the boat, trailer. Good luck:)
proshadetree
I still dont get it a 2 cylinder v/8 what year did they make that?
