1988 johnson 60hp vro....have sorted the starting when warm problem...now when started only runs on two cylinders...top cylinder not firing...(pulled plug lead off when running and no difference at all)only runs on two cylinders at low revs but when put in gear and given some throttle third cylinder cuts in and engine runs perfectly....have swapped leads and still top cylinder which wont fire, also new plug but still no difference....help please
