Re: Low rpm bogging on Evinrude 70 1983
Have you checked the basics?
Good even compression across all cylinders?
Good fuel, proper oil mix ratio
Carb's cleaned?
Spark test to make sure all cylinders have a good blue spark?
Sparkplug's good and gapped to spec?
Carb's to Timer Link and Sync performed?
Around 2500 rpm is actually about the most critical point in any marine engine as that is the approx rpm where most hulls plane and require the most torque (therefore putting the most load) from the engine.
HTH
Compression is 140 on all 3 cylinders
new fuel mixed at 50:1
We have stripped one of them down and it was spotless not yet done the other two.
All sparks are good
All plugs are new and set correctly
I have synced the carbs.
The prop was a 14x17 which i believe was too big as there was only 3mm between the prop blades and the caverty plate. So i have replaced with 13-1/4x17 which i beleive to be the std propeller.
When doing the head gasket i also found that they thermostat was missing so that has now been replaced. The water now coming out of the pee hole is now warm and the top exhaust is now fairly hot! Is this right?
i have recorder a video on my phone of the acceleration.
You can kinda hear me saying the RPM as i go.
www.visitaldeburgh.co.uk/MOV00002.3gp
from starting till 3000 at WOT there is almost no power. then suddenly it just goes as you will see.
Any help on this would be fantastic!
Thanks Steve
