Low RPM for Mercruiser 3.0?
Razvanbuc
I am preatty new to boating and been reading all the post around here about RPMs at wot . My merc( gm ) 3.0 only gets 3000 - 3300 and 25 mph at WOT. The previous owner said he downgraded to 3.0 3 years ago. Does it seems too low considering the boat is a 20' Sea Sport cuddy/cruiser? Thank you
Re: Low RPM for Mercruiser 3.0?
Ayuh,... It has to be geared,+ proped to run in it's rpm zone,...
You're lugging it now,... That Ain't good....
fuzzybob
Downgraded from what? You could have the wrong gear ratio in the drive unit.
Razvanbuc
I bought the boat from a private seller. The boat was parked in the yard at marina down the block. I spoke with the mechanic there who serviced the boat supposely since it was new. My bad I did not ask what they downgraded from. Now the question is how do I find out if gear ratio is correct then what prop pitch i would need? Thank you
CheapboatKev
I'm thinking
You will have to ID the OD & make sure it matches that 3.0
Can you post a pic of her? Call the old marina and ask about the further history of the swap?
Ayuh,... I guess you otta be talking to him again....
Razvanbuc
In addition to my original post.... what is proper gear ratio for merc 3.0? Tomorrow i am dropping by the marina to read gear ratio of OD cover
Ayuh,... 1.98:1....
