So far I've replaced the ignition wires, plugs, fuel pump diaphram and water pump. Compression is 147-150 in all three cylinders, and each plug is getting a good spark.
It starts up quickly, but under load on the water it has trouble running up. Yesterday It would 'try' to speed up, but would eventually die (sometimes stalling).
Before I pull the two carbs for a cleaning, any ideas? The fuel line looks pretty new, but I did notice if I gave the bulb a few squeezes the RPM's would pick up (on the muffs).
Thanks,
Jeff
Thanks,
Jeff
