Re: low rpm skip
I second the compression check...I learned my lesson the hard way. I had the exact same symptoms you're talking about with a '79 V-4. I thought, "surely I have no intenal problems if I'm getting the full rpms and performing fine at WOT". So after spending well over $100 and time on carb kits, fuel hoses, and various ingnition parts, turns out I had 7psi on one cylinder and broken rings. NOt saying this is your problem but I wish I had've checked the compression before I decided to order parts and make those repairs.
