I have an older Gregor 15' aluminum boat with a Johnson 15hp 4 stroke. I recently replaced the prop with a lower pitch. Now it is making a squeak / squealing sound just above idle. It does not make the noise at idle or higher rpms. I added 1/2 inch of rubber under the motor mount but that did not help. It is difficult to locate the source - sounds like a metal to metal squeak from the lower unit, but I also suspect it could be a boat vibration. Any suggestions? Thanks
