I'm going to try this again. I posted this question once but it was deleted for some reason.<br /><br />I have a 1987 Stratos 179V - 150 hp Mercury BlackMax XR2<br /><br />The boat ran great all season. By running great I mean, jumps out of the hole quick and plains off quick and runs 60 MPH (with still some throttle left).<br /><br />Problem....<br />Merc bogs down at 1800 RPMs. When bogging down, boat never gets enough power to get out of the hole even at WOT. At WOT and 1800 RPMs it feels like it starving for gas and jerking. I hit the choke but it bogs down even more or no change at all. I checked the bulb at time problem starts and its not as hard as I think it should be but it does not collapse.<br /><br />Things I did right before problem started.....<br /><br />changed spark plugs<br />sprayed carbs<br />filled gas tank<br /><br />Things I tried after problem started....<br /><br />drained gas tank and refilled<br />Mercury Quickleen (in gas tank)<br />Mercury TuneUp (sprayed in carb)<br />checked for leaks in hoses<br />changed spark plugs again<br />replaced gas hose and bulb<br />Replaced fuel filter<br /><br />I'm leaning towards a carb rebuild. Should I attempt this on my own? Is there anything else I can check myself?<br /> <br />I tried putting the old spark plugs back in and now it runs about 30 MPH but very sluggish. As soon as I put the new plugs in, I cant even get 2 MPH. I exchanged the new plugs for another set and same thing happens.
