The engine is a 'rude 115, '95 60? looper model #E115ELEOC running pre-mix. Fuel is pretty fresh.
At low speeds it's bogging and the idle is very erratic. When I first fire it up it's just plain rough. Once warmed up it'll settle to an idle around 900rpm but if I try to bump it up to fast idle - say to 1500rpm - it'll hold steady then increase on its own to 2000rpm or so then cough and back down to fast idle... When starting off under load it'll hesitate/bog slightly then once up to higher rpms seems to run fine.
I've run the OMC carb cleaner through it recently to no avail.
Any clues as to what's going on?
Thanks,
Rex
Thanks,
Rex
